Flashing green NS on L30ER processor
Kindbluemagi
Mar 2017
Marysville, PA
Hello all,
I am currently having issues with setting up my processor. I was able to get online with it using a USB to setup it's IP. However, after setting this up, I am getting the flashing NS light. I realize this means i'm missing CIP connections. Does anyone know how to establish those? Any help would be appreciated.
Thanks,
Mr. Magi
Just talk to it from your HMI via ethernet. Connecting via RSLogix over ethernet may also sort you out.
Flashing NS is just saying "I am ready to rock but noone will talk to me. I am so bored." I guess it is like a weird teenager in a way. The only way to shut it up will be to take something into its network and tell it to talk to your processor.
So apart from "this LED is flashing and it is annoying" what other issues are you having?
Thanks. All that worked and I figured out it was a stupid mistake on my part. Had the processor set to the wrong IP :( After fixing that, everything is starting to fall into place.
Thanks again,
Mr. Magi
Hello all. I have a remote that uses a 1734-AENTR series C. We had to change it to a new one and, after adjusting the IP and number of slots...
559
Hello. This is for motion experts, and EtherNet/IP and DeviceNet system integrators. I am more into communication and I sometimes need to advice...
921
Greetings, i've got this system: Controller: 1768-L45 2 Modules: 1768-M04SE communicating with two groups of 4 Kinetix 6000 each, (8 Kinetix in...
8,629
all green leds are flashing on a Sercos interface 1756-M16SE module. one axis has module fault 16#10 , sercos ring fault 1 , attribute error code...
4,669
i have a flashing green led on a Sercos interface 1756-M16SE module, on which one drive axis was removed physically, deleted from the program with...
2,265
