Flexi i/o 1794-apb
specialkc
Aug 2005
Calgary, AB
21
Has anyone ever used a 1794-APB module successfully? I have used an extensive amount of Flex I/O in my past life, and have never been fully satisfied with it. That being said I am a little leary purchasing a PROFI card from these guys after being really dissapointed with their HART hardware.
Can anyone comment on the functionality and user friendliness of this product?
Thanks.
I just pulled up your post on a search. did you ever implement using the profibus interface? I am investigating for a project that may need that and I am interested in your experience with it.
russell
Panelview 1400e
Gents,
Is the old 1400e software run only in windows nt/98?
I tried to install it from windows xp os but only the transfer
utility are being installed.
I have a light bulb in an E-stop button fed from an 120 VAC output on the above mentioned module. The light is always ON no matter output is in...
4,244
Hi all, I was hoping someone here may be able to help. I've got to add a Sick Flexisoft CPU0, with a GENT 00000 Gateway attached, to an existing...
3,331
I setup a Flexi Soft system through the designer. All modules have green lights, except for the FX0-GENT status light flashing Red/Green...
3,475
Loaded on Win 10 and it updates and opens project and all is ok. Loaded on Win7 and it wont update ...yes connected to the net. But it is on a VM...
1,546
The attached files shows analog terminations from flex I/O modules to VFD. I have someone telling me that I should use isolated cards instead of...
1,186
