Flip Flop
dronai
Aug 2011
Calif.
145
I have a Micro Logix 1000 trainer with RS Logix Micro Lite 500. I can't find a flip flop instruction.
Does this software have this ?
I will say this politely
Please search this site - you will be in for a hard time otherwise
The answers are already here
I did, and this is what I found. It's just not that easy for a novice to interpet this without an example.
Flip-Flops are ok for a 2-pump alternator, but what if you need a 3-pump alternator, or an X-pump alternator?
I would use a counter, then you have generic logic to create an alternator for however many pumps you need. Using a counter also makes it nice for omitting pumps as well.
If counter = 1 and request for lead then pump 1.
If counter = 2 and request for lead then pump 2.
If counter = X and request for lead then pump X.
If counter = X and pump X not available then increment counter.
If you're really a novice, then I think an X-pump alternator is way over your head. You need to start with the simple things first and then build further on what you already know. At least this is what I've done in my time.
Kind regards,
sorry but keep looking there are thousands of posts
even look for one button push to one output
I can tell you they are there
look at the download library
Understand - this is a typical student training question
so we see this every two months from many students
I might be a redneck, but I am going to upgrade my dollar store flip flops with some fender washers and a grinder. The tie rods keep popping through the sole ... keep having to put them back together, and I am over budget on flip-flops already this year.
Don't quit your day job !!!
If you're really a novice, then I think anX-pump alternator is way over your head. You need to start with the simple things first and then build further on what you already know. At least this is what I've done in my time.
Kind regards,
Thank You
we hve been polite
DID YOU FIND THE DOWNLOADS? - FLIP FLOP is definitely there
You wont get a job in this industry if you ask people to do your work for you.
You Better QUIT YOUR DAY JOB !!!!
Here is a Micrologix program with 9 different alternator (so-called "flip-flop") methods. These are logic methods, not built-in pre-programmed instructions. In other words, you have to write the logic that creates the functions.
I understand you get a lot of people asking the same dumb questions over and over. It's just the sifting through piles of material to find one simple example.
I couldn't find the flip flop instruction that was shown as the solution to this, that's why I asked, if my software even had it. And reply #1 said no it doesn't That's it, back to the drawing board.
You Know this is wrong for you
The australian name for a FLIP FLOP is a pair of THONGS
and well lets just say or version of 'bum bag' refers to a part of the female anatomy
I am having this issue trying to figure out how to do this. I have a Hydraulic ram that travels when a machine is running. The ram extends to the...
31
9,562
Hi everyone, I'm learning ladder logic and have built a flip flop circuit (see pic) from an online tutorial. Closing the switch A is meant to...
19
6,951
I found and fixed issue. B3:3 was used in MOV.
2,608
I am calculating power factor from samples of voltage and current. Calculation is done by multiplying voltage and current samples. What Im...
1,652
Hi all, my first post here, I've been lurking for a while. I'm a beginner and I hit a wall on one of my first projects I'm working on. I know it...
2,554
