Flip Flops
JSPLC
Mar 2009
Santa Rosa, CA
I have been using a memory intensive version of a Flip Flop which uses about 6 words of memory. Does anyone know of a simpler bit level structure to create a Flip Flop?
yes search the site
there are hundreds of posts here
If you want more help then post what you have
Here are 13 methods. I collected these from past threads on this site. I gave credit where I could. Many of these methods have been pasted around programmer-to-programmer for many years.
dont go there ojz0r
over here they are called thongs - yes worn on your feet
slightly different in USA a Thong is not worn on the feet
dont go there ojz0r
And what was it you guys called clear sticky tape ??? ;)
Back OT....
Whichever method you decide upon, JSPLC, and you have a free choice, be aware that not all of the "solutions" available to you behave the same way when the processor, controller, PLC, intelligent relay, etc., is restarted, eg. from a power cycle or a mode change from Program to Run.
Many will not retain the state of the flip-flop, or toggle, some will.
You have to decide whether your application is happy with that, and choose accordingly.
To me, it's a clear-cut choice - whatever "flip-flop" method I use MUST retain the current state through a restart. A restart has absolutely nothing to do with my application logic, so why should it change the state of any of my "memory" bits? I then have a simple job deciding which toggled bits I need to reset on start-up, if any.
Choosing a common retentive flip-flop method throughout gives me the flexibility to use them as the application determines, and not as the software/firmware/hardware dictates.
Thanks Lancie, There are a few on there, I hadn't seen. And I think that Lancies favorite method, may have just become mine.... I like that it triggers on release of the button, instead of activation. Previously I was using method 7
I am having this issue trying to figure out how to do this. I have a Hydraulic ram that travels when a machine is running. The ram extends to the...
31
9,566
Hi everyone, I'm learning ladder logic and have built a flip flop circuit (see pic) from an online tutorial. Closing the switch A is meant to...
19
6,952
I found and fixed issue. B3:3 was used in MOV.
2,609
I am calculating power factor from samples of voltage and current. Calculation is done by multiplying voltage and current samples. What Im...
1,653
Hi all, my first post here, I've been lurking for a while. I'm a beginner and I hit a wall on one of my first projects I'm working on. I know it...
2,560
