flow calculation
ahmed yousri
May 2006
egypt
41
hi
could you help me , i am looking forward to buy flow switch device that can be control the amount of the flow . for example if i want 100 liter of water .just enter required value then flow switch open . after 100 liter flow switch closed .could you recommend the device type which can achieve this conditions
It sounds like what you really want is a flowmeter and a separate valve. Depending on how fast you want to dispense your 100 liters, you would use either a big flowmeter (at the expense of resolution), or a smaller one (at the expense of fill rate, or speed).
You didn't mention if you plan on controlling this using a PLC, but if you aren't, you might use a counter module to count up the pulses and then set an output to turn off the flow.
I did a quick search and the Advantech Adam-6051 looks like it would do the trick very nicely.
You would tie both the flowmeter (a Sensys with a pulse output would do just fine), and the valve (one with a 24 VDC coil should do the trick) to the Adam-6051. You would then program the Adam unit to turn off the water at 100 liters.
Anybody out there ever use the Adam-6051 counter? It looks pretty sweet!
There are batch meters, panel meters that take a signal from a flow meter, which are programmed with a 'preset' (in your case 100L). They have a button for reset, too.
When the flow total gets up to the preset, a relay cycles, cutting power to the valve.
You still need a flow meter and a valve.
Some magnetic flow meters can be setup to total and batch (with a relay output), so that you don't need a separate flow meter and controller.
But you might google batch meter
Yeah, I threw in the controller in case he didn't have a PLC.
And if he is just measuring water, I would render unto Ceasar what is Ceasar's, and just get a cheap residential meter. Wafer mags are fine, but a little bit more pricey than a street meter + a $200 counter.
Dear all, Hope you are well, I have an orifice but no data for it. So i have some data and i need to calculate the flow (mmscfd) passing this...
2,015
Hi, I have AB PLC (1769-L30ER) and PV800 HMI in my project. I have a horizontal tank (same dimension) having a height of 200" and capacity of...
2,072
All, My client is looking to have me calculate the boiler feed water differential pressure in kPa to and actual flowrate in m3/hr. Once the...
1,563
Dear all, I am using Sullair air compressor having model number is Model Number : LS100-30HH/A According to its manual it can provide air at flow...
2,660
Hi All! We have a control panel that houses a VSD in an old shipping container. The control panel will be cooled with a fan and filter unit. So...
2,470
