flowmeter with pulsed output
fizzo
Feb 2009
Kalamazoo
I've read most of the posts regarding flow meters. I think I am over looking something. I am programming a Proface touch screen that has logic capabilities. There is a TM075-N-P flow meter by Great Plains installed. This device provides a pulsed output. The device states 37-370 Hz, 1100 K factor and 2 - 20 gallons per minute.
What I am trying to figure out is how do I calculate the GPM based on this data? I am not sure what the K factor means? If I use the digital output to a HSC and count the value to 1 minute, how do I know the gallons?
The K-factor is the number of pulses per gallon - it's got to be in the manual (?). So if you measure the number of pulses in a minute, divide by the K factor, that should be gal/min.
Pulses in one minute [pulses/min]​
Q [GPM] = ---------------------------------
K-factor [pulses/gal]​
Hi All, I need your help in this task I have to read (visualise) the output of a flowmeter in kg/s on an HMI screen (before I use it in a flow...
2,640
Is it good idea to use ultrasonic clamp type of flowmeter for water dosing? I already using the flowmeter pulse output by setting to 10L per...
1,302
E+H Promag P500 5069 Compact Logix implicit Ethernet IP using endress device description 30ish flowmeters, every time I download, some (but not...
1,277
Having an issue with network timing out when trying to use CIP generic on a Micrologix 1100 B. I’m trying to read flow and totalizer information...
19
5,104
Hi All, E+H Promag W 500, 5W5B1H (Ethernet I/P implicit messaging 500ms) AB 5069-L330ER v33.01* I have a customer requirement where I need to...
1,419
