Flying restart with sensorless vector control on fan
Plc_User
Dec 2005
Belgium
317
Lately I had to commision a some drives for fans.
The motors were 22 Kw, the drives Siemens G120.
Flying restart is implemented to avoid trip when starting a turning fan.
My experience is that when the motor is at standstill that the search for flying restart takes up about 2 seconds and the search current has to be setup very precisely : if too high the fan is pulled during the search, if too low the 'speed' is not found and the fan can startup up shortly in the wrong direction.
What is your experience with flying restart on sensorles vector control?
On the drives I'm familiar with (ABB mostly) you simply turn it on or off. The drive is smart enough to figure out how much current is enough and how long it should flow. It certainly is useful, both in sensorless vector and V/Hz mode.
I'm in the midst of commissioning a number of these units and I'm having a trouble with a flying (re)start. The short background is that my PLC is...
1,770
Hi, I have a G120 PM140 IP20 Power unit with a G120 CU240E-2DP Control Module driving a 45KW motor with a fan directly attached. The fan is in...
2,381
The PLC is a A&B L71 the servo drives are Kinetix 5500. The machine is two presses and a roll form machine. One press is before the roll form the...
2,521
Hi All, I Have a question, I am very thank full to you if help me, I designed a flying shear controller based on fpga and microcontroller, but...
20
4,428
My customer wants to add a DC controlled servo valve (0-10 VDC) to an existing and working flying cutoff (steel pipe mill), nowadays saw is move...
2,856
