FM steper driver..
Farid
Jul 2004
UAE
79
HI all,
I have a simple indexing application, which I've decided to use a steper motor for...
the steper motor used is SIMOSTEP and it generates 17 newton meter...
now my question is:
can I drive this motor by using FM steper drive which is compatible with S7200 positioning module and I can use the wizard in microwin to generate the required movements and subroutines...or should I use FM353 which is compatible with S7300?? cause I only have microwin and I dont want to
buy step 7 ,
the local siemens rep has quoted FM353 and I don't knnow why...still waitting for his reply...probably tomorrow, hoppefuly he will explain why he did not quote for the FM driver(which is compatible with S7 200)instead of FM353..
I am not familiar with S7300 plcs...and I wanna stay away from it as could as possible..so..
what do you think guys..any inputs ?
best regards.
I would recommend the EM253 stepper module for you since you have experience with the S7-200. PN 6ES7 253-1AA22-0XA0
The FM353 for the S7-300 is a complicated beast especially if you do not have any S7-300 experience.
If the SIMOSTEP motor is just a stepper motor, you also need a drive between the motor and the EM253 module
Dear All, I wish to use on stepper motor in my line to rotate a object by one and half round. object is round like a disk and weight is approx 10...
1,552
Hi every one I am learning plc and I need some one to tell me if it possible to write a plc program to control 2_phase steper motor 2.8 V dc 1.7...
2,388
Hi, I have an iFIX 5.5 project (Windows 7) that needs to be updated to version 6.5 (Windows 10). iFIX communicates with the "Siemens Industrial...
179
Hello guys, I'm trying to use the Lenze GDC 4-14 with the system bus adapter 2177, but it doesn't appear in the communication window. It's like I...
235
Hello all. My rslinx freezes for several minutes each time a USB device is browsed. I thought I was freezing indefinitely, but disabling...
618
