Fm350-2
aiskandar
Sep 2016
Syria
Hello everybody,
I'm still beginner programmer and I faced a problem with FM350-2.
I use CPU 315-2 and FM350-2 to measure flow rate as totalizer with an incremental encoder.
during few a days ago we have power failure take 4 hour to restart the station after our totalizer not reading at HMI but we have flow rate reading, check the following:
Flow meter found ok
Visual Check for FM350-2 found no alarm
Do diagnostic check for Modules found ok
Check address between HMI and DB system found ok
I would check the output of the incremental encoder to ensure that you are getting the signals sent to the card.
Regards,
I have a S7400 414-2 DP fw5.3 with a CP443 6GK443-1EX30 fw3.0 and FM350-2 on profinet The interface module is a 6ES7153-4BA00 fw 4.0 (ET200M...
1,917
I am using FM350-1 with S7 315-2DP. I use the counter module to count the encoder pulses and cut a crossing plate on the desired position. I do...
1,744
I am trying to replace an old Relience system with S7-300. The system has an encoder that uses external 220V supply and has 12V A,A*,B,B*. As...
1,151
For a revamp we will have a configuration with S7 1500 and FM350 in ET200M on profinet. Will the FM350 work? Because I see in Siemens Tia...
2,753
Dear All, Hw config. are 317-dp cpu with FM350-2 counter modle. Connect HTL encoder A to FM module nr 5 and B to Number 8. (mean channel 1)...
1,853
