FPWin GR - File Uploading Error
mczubek
Sep 2017
Stoughton, WI
Hello,
I'm new to this forum and PLC programming in general so in the responses, please explain things like you would a 5 year old. Thanks in advance.
My problem is, I have a Panisonic PLC which I need to connect to in order to change the program. This PLC requires the FPWIN GR software. The information for this system is below. Whenever I try to upload from the PLC or open an existing file of the program it tells me this error.
"Program File. Impossible to read. This PLC type is not supported." The file type is an *.fp and is 30kb. The program can open other *.fp files that are 16kb and smaller.
The System information is below:
Windows XP Pro Version 2002
FPWIN GR Version 2.70
I tried to compress the program file and open it that way with no success. I'm not sure if my program is missing something or what. Please advise.
I'm writing some alterations to an FPWin program and need to see the running value of timers so I can set them correctly. It's my first time with...
141
Can someone tell me what I'm seeing here? I'm online with the FP2 and looking at some rungs with DT120 and DT124. Each are used twice and each...
1,739
YIKES!! I have done most of my training in RSlogix and making a retentive timer has never been a problem. I recently took a job converting...
2,083
I have been working on an existing project for some time now and restructured the whole program into POUs instead of a singular main. Everything...
18
3,234
I have an older (2006) Panasonic FP-X C14R that i need to connect to. I have zero experience with Panasonic PLC's and the FPWIN Pro7 software...
2,330
