Frustrating PLC issue
nua4ssss
Jun 2015
mass
Hi All,
I have a machine that is using a Allen Bradley Micrologix 1200 with a panelview 600. Everything was working normally but we had to unplug some wires to change some components and we are now getting the following issue:
I am getting an Error 208, unable to write to remote device and when we touch the screen we get an 683 file access error. We checked the wire connections and everything seems to be secure. The PLC and Panelview are the same and we did not make any changes to them.
Any help will be greatly appreciated!
To me it seems that the Panelview can not communicate with the ML1200. I would trace that cable to make sure it is solidly connected at both ends & didn't come apart in the middle, if there is any termination or plug/receptacle in the run, or a powered adapter/switch that's not plugged in.
Have you tried cycling power to both devices with the communications cable connected between them? What communications protocol is being used (DF1 DH485)? What are the LED’s on the 1200 doing (is the “fault” LED lit up and/or flashing)?
Hello all, I am a Rockwell guy and just started with siemens. The data sctructure frustrates me. Especially the swapped bytes. Can someone...
1,647
Hello, I have a problem with Vijeo Designer (6.2 SP3): I want to create an action which trigger a script and inside this script I want to use...
2,372
Hello everyone, I have been attempting to complete a simple weight conversion program... basically it loads in 3 values from a BCD Thumbwheel...
2,983
Here's the deal.. I've got a PIII-866 motherboard with an ISA slot. I put a 1784-KTX in (set to D700), and loaded XP and RSLinx 2.50 on the...
2,853
HelloI need software to download the program from PLC EH-A28DRP from an old machine whose manufacturer does not exist. It may be Ladder Editor for...
