FT Run-time screen resolution
ezz_snake
May 2012
Giza
hello all ,
I am new to this forum and also new in using RA's Factory Talk View SE so i am going to ask a simple beginner question
Now i Have A project to make and the Run time will be on (20 inch Square Display)
What is the best resolution or dimension of the Display editor should i configure in factory talk view SE V6.1 ?
is there a standard dimension ?
Thank you very much for your help and Best Regards ..... :)
Set the resolution within the System/Project Settings/General by choosing the terminal type the application is going to be deployed onto.
For example, for a PanelView Plus 1500 terminal, the global resolution (passed onto every configured display properties) will be 1024X768 pixels which is the native resolution of the PV+ 1500 HMI terminals.
Of course you could choose any resolution you wish, however, you should try to stay "close" to the native LCD display definition.
Hi, Is it possible to have a background script running behind when a settings/log screen is triggered? I know i can run a script on Screen...
7,917
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
39
Hello..I am new to Plc.I have Mitsubishi Melsec Fx3Ga-40MR PLC controlling a machine for packing powder.Currently the Plc has issue which power...
164
I'm looking to get some spare keys for this PLC. Does anyone know a source or have a part number? My searches are turning up nothing at the moment.
99
I have a few questions about Studio5000. 1. Why is my RA folder so big? its well over 100 GB. 2. How do you delete versions or extra files...
294
