ft view Remote
Hojland
Oct 2006
Langå
203
I have an machine that can be remote controlled by FT view me on a PC. But can I some how get a bit to go high, when the pc i connected an ft view is online with the application? I need it as an alarm, so it can be visualized the some one can start or stop it remotely. warring light
Under Tags system folder there are two Digital Tags called BlinkFast, BlinkSlow. Use a Macro in Remote PC project to Create a Heart beat Tag. Monitor Heart beat tag in PLC using two timers one with NO contact to run timer and one with NC contact to run the other timer. If either timer is done then remote PC is OFF.
The only problem is running Macro Consistantly.
Or under Global Connections Date and Time use the Second Expression. This is an analog tag that writes 0-59 from the terminal's internal clock you just create a Tag in plc and check to see if value is Changing. I think this is a better Solution. Set your output interval to 1 Second and Maximum update rate to .05 No need for Macro.
Hello, I presently have a Allen Bradley PanelView 5310 at a client site and i can access to the PLC/HMI local network with a remote module...
108
Hello, I have a machine with a 1756-L72 Controllogix PLC and 1756-EN2T network card, and PanelView Plus 7 HMI. I am using RSLogix V20.05.00...
922
Hey All, I am experiencing issues connecting my FTView to a remote network. When i expand my Network and Devices tree (Left panel), my...
935
I am hoping someone here can help me out with Remote Desktop Connection Manager. On my clients an on my ThinManager server my screens size fine...
701
I am trying to copy a .csv file from a PanelView's SD card onto a a remote windows server. I understand that the panelview does not allow you to...
2,179
