FT View Save Multiple Data Logs
fasacrifice
Feb 2014
Vancouver, BC
89
Hi All,
I'm using FT View Studio v8 with PanelView Plus 1500.
I need to save 2 separate data log files into USB but it allows me to choose only one to run at the start up.
I need one to save all the info periodically. and the other one for to be saved only when there is a change.
And also is the USB must be plugged in before powering up or is it OK to insert in while the HMI is ON?
You need to use the active x data store plus. AB has an example of this in the sample code library.
KB 520349
If you don't have access I can post up the example tomorrow
The USB must be in before the log is started.
The log you are taking about cannot be saved to a USB and is limited to 100 tags.
If have also found that anything bigger than 2gb freezes the hmi at boot
I have encountered the same issues.
The fact is that FTView is rubbish for historical data.
You can only run 1 log, no way of running 2.
It is very limited in the amount of data it will store, and has no way of storing historical files. So when the data limit is reached, it will wipe the old data.
Best option is to use a separate data logger.
You can store multiple logs using the active x data store plus
Hello Folks! I have an issue and its very often but in this case i applied all the tricks and tips that i always do in similiar issues but in this...
783
This is a very basic question regarding whenever I close any Display, Library etc. It asks me to save changes all the time even without any edits...
851
Hello Everyone, I created a Recipe View and i plan to use it on multiple presets, change them, rename them, delete them, add new ones whatver i...
4,705
Hi I would like to ask on where will I store my logging path where I can save the data logs even after a power cycle. I'm using a PVPlus 7...
1,361
Not really a PLC problem, but was hoping that maybe someone here might have some insight into this issue. We have several panelviews setup around...
1,196
