FT View SE Client issues
rrparker07
Jun 2010
Winston, GA
89
Just installed FT View SE Client version 7 on a replacement XP machine. I'm running a network distributed application on a server. I copied the .cli file from another machine and am trying to run it but I'm having no luck. It runs but then asks for security info. Tech connect article guided me to placing new machine name in the FT Admin Console so I did that. I know that it took because now when I pull the app up in Studio, the computer shows up in the directory (the console and HMI server are on two separate vm's on our IDC). If I run the new client wizard, it tells me that it can't find the application. I know I'm on the domain because I can ping both ways and my site licenses show up in Activation Manager. I don't have much SE experience other than editing and any help is greatly appreciated!
Have you pointed the new client to the directory? The .cli file is just a configuration file that tells the client in what manner to run the SCADA application from the server, but the application itself still resides on the server, not the client. The client only knows where to find the server (and therefore the application) if it's got the FT Directory configured to tell it where it is.
I've been trying to. I think the issue is the Ft directory may have a different PW than the login to the server itself. When I run the "Specify directory location utility" it asks for a PW and I don't have that. Will have to wait until tomorrow to see if I can get that. Thanks
Hi Everyone, I'm recently working with FT View SE Network and I'm having issues configuring the client. I've followed all procedures set out in...
3,034
I used vmware converter to clone and backup a physical pc FT View client and now after removing vcenter converter and rebooting I am getting a...
80
Trying to do some work on an FT View SE server and I don't see a client to be able to access the historian. Should there be a client to access the...
177
I am working at a remote site that has a FTView SE system that has been running for years...V9. About an hour ago the operators called me over...
690
What is the Correct way to move Client files (FactoryTalk View SE)? I have FTVSE Studio installed on a development PC, I created a FTVSE Client...
1,170
