joaco1993 Lifetime Supporting Member J Join Date Sep 2014 Location newyork Posts 237 Apr 6, 2020 #1 Hi everyone, Is there a way to put in the parameter file a parameter that is a negation of a tag ? For example: #1= NOT ValveClosed So when ValveClosed is 1 then #1 is 0 Thanks!
JaxGTO Member Join Date Apr 2009 Location Kalieefornia Posts 1,071 Apr 6, 2020 #2 You can only use tag references. You would need to make a Derived tag and use that.
joaco1993 Lifetime Supporting Member OP J Join Date Sep 2014 Location newyork Posts 237 Apr 6, 2020 #3 JaxGTO said: You can only use tag references. You would need to make a Derived tag and use that. Click to expand... Thanks JaxGTO, thats exactly what I decided to do minutes ago..
