FTVIEW 6.0 Windows 7 and ActiveX
DD63_FR
Feb 2011
FRANCE
Dear All
I have a question about the ActiveX and FTVIEW 6.0 on Windows 7.
I have develop an application on FTVIEW 5 and use on Windows XP PRO, with no problem, I use activeX windows Media player on it.
When I use this application on the new PC with WIndows 7 the active X don't work. I try to developp on FTVIEW 6 with Nex active X the same.
Do you alreday have this type of problem?
Thanks for you answer
Have a nice day
DD
Offhand, I'd say it is most likely the more stringent security features of Windows 7. Check ALL of the Internet settings, and try reducing security.
I don't know of a way of explicitly trusting an ActiveX control on Windows 7.
Hi, thanks for you answer, I'm not sure the problem come from safety, but in fact the activeX was not found when I start on Windows 7. I don't remeber the exact message I post it.
DO you knew how to add activeX on FTVIEW?
If it comes with an install program, use that, and note if there are error messages. What might be happening is that the ActiveX is trying to load itself to a hardcoded location (or the client frame is looking for it in a hardcoded location), and it can't find it due to the directory structure change of Windows 7. Active X programs can also be autoloaded if the server machine has a properly configured .CAB file in a valid location on the server to find.
Also, make sure you are running a 32 bit version of Windows 7, not 64.
And I say it can be security, because Windows 7 is MUCH TIGHTER then Windows XP ever even dreamed of being.
Gentlemen - Our site is in the process of upgrading our clients from Windows 7 to Windows 10 (SE version 9.0), and we have a couple screens that...
4,291
I have an FTView SE (V9) application that is using VBA to create a .CSV file and saving it to a specific folder on the hard drive. The operator...
1,796
Hello... I've just had to buy a new lappy and it came with Windows 8.1, no options for W7, and I'm stuck on site with only my Studio 5000 v21 and...
22
11,281
Guys, does anyone know how to run FTView Sudio 6.0 under Windows 7 64 bit? Rockwell says: use VWware, but this is not allowed by our IT man. I've...
2,985
Hi folks. I have a system that I'm working on that needs 2 alarms banners with different event subscription: - One banner for a specific area...
83
