FTView help
Nebul0us
Dec 2015
Spokane, WA
125
Hey all, it's been a while since I have used FTView. I am currently using FTView ME v13.0. I have two questions...
1. Is it possible to import an image with background transparency? I have tried to bring in a .png with transparency to no avail and I kind of remember that this might not be possible in FTView ME. Probably just another reason I hate this software so much...can anyone either confirm this or tell me how to do it?
2. How can I make a vertical analog indicator to show the level of a tank? See attached image for reference picture...
I remember doing something like that where I needed the bar graph to be green in the middle, yellow warning bands above & below green, and red above and below the yellow. I don't remember the details, but I remember using more than one bar graph stacked end-to-end, each handling part of the range. A single bar graph can handle up to 2 thresholds, but I needed more than that.
I just added an image of mine with a transparent background. It worked fine. It is a PNG file.
Rockwell's bar ground object does indeed support two thresholds. So that is three colors. If you need more than that it gets tricky.
I would create a vertical rectangle and apply fill animation to it. Then duplicate it and modify the range of values (min and max) and color. Rinse, lather, repeat.
In my example, I did this to create six different color thresholds. I just used the seconds tag for demonstration purposes. If you don't want to see the outlines for each rectangle, untick the Inside Only box for each item. Then draw a rectangle with a transparent background and a black foreground around the whole thing. Example of each method on the far right.
OG
Hey I am trying to used the ISATR8800002_2015 from machine builder library, and when I try to use the HMI i get the error cannot interpret area...
714
Hello there, Due to shortage of panel view and Rockwell supply chain, I want to implement a smart tv to cast a process of a PLC through the...
2,399
I've used FTView ME for as long as I can remember but am now developing an application with SE. I've imported an ME project that will serve as...
1,491
Hello all. It has been a while since I have worked with FTView Studio and having trouble remembering how to open an .apa in studio. I can't...
3,188
I'm converting a Citech SCADA program to a FTView ME program and I've run into a button logic issue that i have to be over thinking. I want to...
23
4,523
