ceilingwalker
Hello all. I am trying to establish my connections in FTView Studio. Normally, after I have set up my offline tag file in communication setup I then create an action object, under "Connections" in the properties dialog box, I select the "..." under the "Tag" heading and it brings up my tags. I haven't done this using VMWare before, this is my first time. When I do, it just sits. It won't allow me to do anything more so I end up hitting escape after a while and then I just close the dialog box. When I verify the processor in coms setup it gives me the thumbs up so I am not sure why it doesn't open the tags db for me to select. Is this common with the use of VMWare? It's the only place I have seen it. Thank you
