FTViewME program locations
LoganB
Apr 2017
Michigan
607
Hello members! Long time no post! I hope everyone is doing well and enjoying the new year!
Today I have a question about the default program storage location used in FTVME. I'm not referring to APAs or MERs, but to the actual file structures. The default location on Windows 7 stations is:
C:\Users\Public\Documents\RSView Enterprise\ME\HMI projects
Is there any registry change or something that can alter that location and make the program use a network location instead without breaking a bunch of functionality? I'm envisioning a pool of programs that we can all access from our workstations that will reflect any changes made by previous programmers. Has anyone ever looked into this?
TIA!
I don't believe there is a way to customize the file path for Rockwell programming software (SE or ME). I would suggest looking into their Application Code Manager tool though since this is specifically designed to do what you are trying to - creating a centralized repository/library for several people to use. It is also not limited to only HMI development, but can combine PLC logic, Add-on Instructions, UDT's, etc also.
https://www.rockwellautomation.com/...ucts/studio5000_application_code_manager.page
How many team members are you looking to create a library for?
Currently only about 5, but part of the problem is three are on first, one on second, and one on third shift. So not all the programming is happening while we are here on first, and those off shift guys seem to always forget to update the APAs on the server and we end up wiping out their programming changes.
I'll check into Application Manager, I took a lab on it at TechEd and it seemed like a cool package. I was hoping to be able to make some sort of "gray area" change in the registry instead of needing another firstborn sacrifice for an additional Rockwell package :ROFLMAO:
TIA!
It wouldn't be as simple as just clicking the address bar in the dialog box and browsing to a different folder while creating a project, would it?
Nope, not that easy. View does not give you an option for where to store the application itself. It has a fixed location where projects are stored.
OG
It would definitely have to be done in the registry, I haven't been able to locate any sort of program option to change the location. Rockwell live chat said that there wasn't any way to edit it, though I think that really means there's no *suggested* way to edit it... I'm sure there's a way to do so, but I don't know what the side effects would be.
I have an issue Im trying to overcome and I think im just over thinking it. Maybe you all could help. Operation description.... 1) Operator...
3,415
Evening all, Hope you all had a good Christmas and new year. I was looking for some advice, I have looked through the forum and found several...
1,799
Hi all, Two questions reqarding factory talk view machine edition: 1) Button How do you place a button on HMI which write an integer into an...
2,127
I've been asked to add a trend to a PVP HMI. Its only a basic HMI with 5 analogue values that need trending. They are all tank levels scaled...
1,530
I used the FT View ME conversion tool on an existing PanelView standard program I had. The conversion worked and no errors were generated. In a...
5,700
