Fuel oil tank level
tcarafi
Jul 2015
Fort Worth, TX
Good day everyone.
I have a pending project regarding tank level. This company wants us to set up a sensor for the amount of fuel oil in a single tank at any given time.
Our idea as a company was to install a pressure meter at the bottom of the tank, in order to find the height of the liquid, then the volume.
My question is the following: would a Siemens SITRANS P DS III sensor work for it, considering the liquid in question (fuel oil)? Would the sensor become corroded at all?
What size is your tank? How accurate do you need it to be? Do you need to interface with a PLC or HMI?
It's a 2.5 meter diameter, 5 meter long bunker C fuel oil tank.
I need an HMI, and the purpose is to calculate the volume of oil in the tank.
Is it a better idea to get an ultrasound sensor and set it on top instead?
Head pressure works for level, but the result is density/specific gravity dependent. Physical level (elevation) is a calculation: head pressure/specific gravity.
Say the level is constant but the density changes due to temperature. The indicated level (from the transmitter) will not change because the head pressure is the same, but the physical level will change due to the temperature related expansion or contraction.
Corrosion is unlikely, because Siemen's wetted parts are at least stainless steel.
That is a small tank compared to what I am use to.
You should have a bunch of options for a tank like that. You an use Float, Pressure, Magnetostrictive, Ultrasonic and Radar. A lot will depend on how accurate you want to be, what is available in your area and the budget.
I would take a look around and see what you can get your hands on maybe call a local company that specialises in level measurement and see what they have.
How much do you have to spend??
I have used static pressure instruments in the lower part of the tank with good success. And you can make the display tell you how much is in the tank, and not have to HMI it??
John
One important thing: Make sure that you get a system that is rated for the hazardous environmental conditions of the material in the tank. If it is a vented tank you will need Class 1 Div.1 rated equipment if you will have any electrical connections on it.
I've used ultrasonics for this sort of thing (tank level measurement) on a few different projects and it's worked well. Pretty simple to program and install.
Up here we use Titan Logix TD-80 Level Sensors on fuel and oil trucks, great mobile product, good temp ratings, also Class 1 Div 2 rated for explosion risk areas. It uses Radar and time of flight to measure the distance from the top of the tank to the fluid level, volumes are calculated by the unit with a strap chart. To connect to an HMI, the unit comes with a 4-20ma output and I convert that to distance, from there I have a strap chart in the HMI or PLC.
Unit runs on 12-24Vdc, I typically use 24Vdc as the 4-20 seems to react better. There are probably hundreds of thousands of these units in service around North America, most oil field tankers use them, but they can be used on all types of fuel and water/liquids. The in-tank components are all stainless.
Might look them up and see if that is what you need.
Howdy everyone from the great city of Milwaukee, hope everyone is having a good week...I have an application, which I'd like to use a submersible...
17
8,592
Hello, I am doing research project focused on the retrofit of a diesel locomotive into a hydrogen-fuel-cell-battery hybrid locomotive. The...
535
Hi, I am looking for a sensor to monitor the level of Diesel Fuel And Gasoline in an outdoor Storage tank. The Tank has cylindrical shape laying...
1,854
Greetings from all the way down here in New Zealand:-) I have a challenge for you all..... I have a need for a PLC to run a Doser pump to pump...
34
11,267
I am about to be upgrading several compressor engines to Logix 5000 and I am looking for the best, proven, ways to program in the various curves...
2,055
