Guys, It is a 40 HP continuous, 90 HP peak, 3 phase AC motor. It is a Siemens 1PV5133 and should run about 240 RMS on the AC side. I want to put it in a car.
REPLY I intend to convert 56 Chev pickup with 50 HP Leeson 3550 RPM.
You may want to search the forum for the posts i have put here over last several years on this subject. Got very good responses and encouragement and education.
AC drivers are not available for this motor. Actually, there are not too many AC drive solutions for this market.
REPLY The AC drive providers in the EV business say you can only use their drive with their motor. this may be true if you go with their plug n play package where they have the entire setup all prewired. Azure does this and to some extent Siemens. Generically any VFD will drive any squirrel cage 3 phase motor. See below if using off shelf industrial VFD.
Whatever is out there can cost from $5K and up.
REPLY Oh yes
A guy named Eric Tischer just did this and it was featured in Wired magazine. He bought an SSD drive and replace the IGBTs on the output side. On the input side, he bypassed the rectifiers and went straight DC into the drive (240 RMS*1.41 - 340VDC from batteries in series). Anyway, I like the concept and want to do the same thing.
REPLY I looked over his website quite closely. This guy is one sharp cookie have no doubt. He is in the automation business so he should know something about drives. In essance what he did is take the output module ie IGBTs sized for his need and connect them to the brains out of a smaller drive. He reported several bugs still left. I suppose I could do the same thing and would have no problem electrically BUT he had the software and the programming expertise to change the software - that I do NOT have.
On a general note, anything you guys can throw out as potential obstacles would be helpful.
I am trying to pick which drive to purchase. AB drives are expensive but well documented and have this "Force" technology that is supposed to have zero torque at low RPM.
REPLY Please send me the link - would like to look at it.
I just can't see that in the specs for the other drives. I see that folks on this site pretty much give a thumbs up to the SSD/Eurotherm/Parker drives too. I am not opposed to them, I just want to make sure that I can get full torque at zero RPM. Sorry for not mentioning this all sooner. I know that the more information provided, helps you guys. I just didn't want to put anyone to sleep!-Rjay
I am intending to use off shelf industrial rated drive for several reasons
1. Mass production should lower cost
2. In field use for at least two years
3. More applications should ensure that someone else has worked out the bugs.
4. Local support - parts, technica l, warranty etc.
5. Industrial is what I have worked with for many years.
Off shelf industrial VFD -- The trick is to
1. get the 325 VDC to the DC bus. I intend to use 2/0 copper for cabling but VFDs seem to rate their terminals for 1/0
2. You need to keep the capacitors to allow VFd to stay energized to let EEPROM do what ever before deenergize
3. connecting battery direct to DC bus bypasses any precharge circuitry. This is needed to prevent capacitors from blowing as result of uncontrolled inrush current I am told.
In theory you could use a planar "volt/freq" drive. They will give full torque at low RPM. The problem is they do not correct for slip. So assume 3600 RPM motor with 50 RPM slip
and 3600 motor RPM = 60 mile per hour = 60 Hz.
At low speed ie 1 mph with planar the command is 1 Hz and motor should do 60 rpm but subtract the 50 rpm slip now you have only 10 rpm maybe. Vector takes care of this so at 1 mph or 1 Hz command you will get 60 rpm out of motor.
I am deliberating between Hitachi SJ 300 or AB vector drives
AB designed for purpose NO ADAPTATION ie connect direct to DC 325 bus price tag $6,000
Hitachi not designed to connect direct WITH ADAPTATION to DC bus - will have to build precharge circuit and bypass relay and some other tinkering around. Terminals are rated for 1/0 - I want to use 2/0. Price tag 4400.
I think the VFD and the motor part is the easiest to implement on vehicles. The hard part is getting correct components ie relays disconnect switches fuses rated above 325 VDC and am finding will end up with stuff in 5 to 600 VDC range. This is all industrial stuff so they are big and packing them into a car is a trick.
You may PM me if you want more info.
I will not hog the forum further with more of my findings
UNLESS there are five votes for me to keep blabbing onward.
Dan Bentler
