Fumis biomass controller
Zihc
Sep 2020
Ljubljana
Hello guys
I need your help.
I have fumis pellet controller and i want connect on him.
Manufacturer have the signal converter called ucome,but is expensive.
I want to know if i can buy similar produce on aliexpress?
Thanks for your help
that looks like a USB to RS232 converter with an RJ45 connection
you should be able to get something for but your real problem is the software to nd coud be very expensive
Has anyone done this type of an application before or can point me in the right direction? Biomass is corn husk. it can be partially dried or...
1,768
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
55
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
44
175
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
53
