FX3G communicate PC with VB
tid_champ
Mar 2011
bkk
30
Hi
I want use vb2012 communicate with PLC FX3g Non protocol . Please show me sample VB2012 code for read/write 1 register.
Thanks.
I have no idea what PLC FX3g is, but I've done this with AB, Omron, and GE PLC's. For each of them, I had to have a "driver" that would handle the communications. I chose the ActiveX route because I was doing it starting in Visual Basic 6 and that's what worked best.
For the AB and GE I was able to purchase, or was given the ActiveX control that I used. For the Omron PLC I wound up having to write one as the Engineers at Omron failed 13 times to deliver a working ActiveX control. I got fed up and just wrote it myself...took awhile, but it worked!! I imagine that you'll have to do something similar to get yours to work...first see if someone out there has written code that will handle the communication for you. You may have to pay them a bit, but it is WELL worth it if you can start coding your project right away!! If you can't find one, you may have to build your own...if you are not up to that task, contact me and perhaps I can help (for a small fee of course)...but I would recommend doing it yourself, you'll have a MUCH better knowledge of the entire process if you do!! Good luck and let us know how it goes!!
I have added 4 in and 4 out analogs by two cards, a 4DAP and a 4ADP. FX3U-4AD-ADP FX3U-4DA-ADP The manual shows that the registers are near the...
28
3,057
I have encoder connected to FX3G and stepper. What I want when I rotate encoder it moves stepper. Encoder sets position for stepper. Or each pulse...
2,203
I have a client with a Mitsubishi FX3G-60MT PLC the machine is Chinese only 5 years old and surprisingly its build is good. however.... its PLC...
3,383
Hello Friends I need to communicate these devices. Is it possible? How can I do that? The marker supports RS232C and Ethernet, which could be...
1,137
Hi all, I am totally new to the PLC world and I already face a major obstacle :) I am trying to control a really simple pneumatic system using...
1,460
