G3 database upload
JeffKiper
Jun 2006
Indiana
2,462
I have created a data tags that are retentive.
Can I pull them out of a G3 and edit them in a Excel, Wordpad,etc.? I want to test out a sort function that I have. I also have about 100+ known variables that need to be entered
Export tag database, edit (opens with excel), save csv , import tag database. Although the tags are retentive, that only means they remember their value on power up. The values themselves are not saved in the database. Use the program section to declare what the tag values should be (set read when referenced)and on "page setup" choose the run at startup option eg. Run (Program1)
Exporting to a speardsheet is my prefered method of editing the properties of my tags.
Hint: Create a tag exactly like you want then export to see how that information is displayed in the spreadsheet. This a real handy way to adjust the properties of the tag (color,font, etc..).
I'm using Crimson 3.0 to set up a Red Lion PTV. Learning Crimson was pretty easy, once I worked out the addressing convention quirks. One issue I...
1,862
Hi I tried to upload a panelview program (a copy of the original program is not woth me). The uploaded .pva file was converted to .pba and...
6,110
I’ve been tasked with extracting PLC (logix 5572) realtime data, storing it in a database (anything compatible with our data) and displaying it in...
49
We are a water/wastewater plant, collecting realtime and manually entered data. We have been using FactoryTalk Historian (OSI PI) for real time...
155
Hello to Everyone all over the world: I don't want to reinvent the wheel so I am asking others if they have programmed something similar to this...
299
