Ge 90-30 Communications
pauly
May 2002
South Wales,U.k
244
A customer of ours has requested two GE 90-30 plcs to be connected together using cmm311 communications co-processor cards. The last time any GE PLCS were connected together we used the Genius communication modules. Does any one have any experience with the cmm cards? Reading the manual it seems that the actual communication tasks are instigated from the Ladder software. Is this the case or does the panel know of an easier way given that we have two cards with the same protocol.
I agree that it would be easier with Genius communications.
To use the CMM311 card, configure one of the ports on the card as an SNP master in one PLC, as an SNP slave in the other PLC. In the PLC with the SNP master, you will need to add ladder logic to control the reading and writing of the data to be exchanged. You won't need any logic in the slave PLC to receive the data, but you may need logic to put the exchanged data in consecutive memory addresses (just as you might have done when using Genius).
I've been dealin with some intermittent CIP explicit messaging issues. I tried reducing the amount of small MSG instructions and converted them to...
18
407
Hello, I'm trying to delve a little into rs-485 communications for a couple projects of mine. Until now I've been using a delta vfd and a delta...
131
Sorry if this has been asked before, and apologies if this seems like a trivial issue, but I am new to Beckhoff and have been banging my head...
172
I have a curious question and I can't seem to find any information on it. I'm hoping I'm just overlooking something simple. I have 4 machines...
474
Multiple PLCs in our plant communicate using either MSG instructions or Produce/Consume. Is there an industry best practice for documenting this...
776
