Ge-Fanuc 90-20 PLC
supaportagee
Nov 2020
RI
Hello, I have a machine with a Ge-Fanuc 90-20 PLC that was recently moved to a new building and now is not working. The program is OK but a sensor or something silly is causing the machine to not work.
I have Proficy ME but I think this PLC needs Logicmaster which I do not own or know how to use. I think I am going to upgrade this PLC now but was hoping to upload the ladder logic so I can copy it to the new PLC.
Can someone confirm if Proficy ME can upload the program from the PLC? Is there a way with a new software to convert this program to be used on a new PLC? If I find a copy of Logicmaster can it print the ladder logic? (as this is a DOS program). And if I do upload or print the program, it will not have labels so is it even worth the hassle to get the current program off this old PLC?
Im a newbie so any advice is much appreciated.
Thanks,
Paul
I don't think Proficy Machine Edition is compatible with the 90-20. When I create a new PLC project in Proficy I don't see the 90-20 as an option for the CPU.
Send me another PM with your email address and I'll send you Logicmaster. Unless you also have VersaPro. The VersaPro installation CD has Logicmaster on it. Logicmaster can produce a text file of your ladder logic with no variable descriptions or rung comments.
Hi, hope you doing well I am looking for SIEMENS PLCSIM equivalent in GE FANUC PLC, RX3i PLC thank you
55
Got an old machine with a IC610CPU104 CPU. A bit of research told me this is the same as DL305 so DirectSoft from AutomationDirect should work...
2,174
Dear Everyone I work with PLC GE-Fanuc. But I don't know that "PLC GE-Fanuc (Series 90-30 and VersaMax) can Online Edit Programming while...
3,139
Our PLC output 7 opens a valve to move a cylinder rod. The output turns on every minute. The output is supposed to be ON for 10.56 seconds. But...
2,943
Need to find where to get VersaPro or Proficy software for the GE Fanuc 90-30 PLC.
2,575
