GE FANUC 90 series PLC Communication
Jing Zhi
May 2004
BEIJING
Hi, all gentlemen
Before, our plant use GE FANUC CPU350, only one port on the PS mould can connect to laptop. But now we change to CPU363, both this CPU and PS mould have the same port, additionally, the CPU mould also have a RJ11 RS232 port.
I do not know which one I can use among this 3 port to connect to my laptop?
Please kindly help me!
If I have made any mistake on the language please kindly correct me, this will be great appreciate. And, forgive me since my Chinese style English.
Jing Zhi
You can connect to any of the three. For the 15-pin (Port 2), use the same RS485/RS232 converter that you use with the port on the power supply. For the RJ-11 (Port 1), use cable IC693CBL316.
The above assumes that neither of the ports on the CPU have been reconfigured to use any other protocol.
Got an old machine with a IC610CPU104 CPU. A bit of research told me this is the same as DL305 so DirectSoft from AutomationDirect should work...
2,069
Hello Does anybody have FANUC series 90-30 PLC configuration softwate? I need it . I have a big problem, Please hepl me...
1,771
Hi guys. Im a total PLC noob. i suspect a dead 331 cpu. Unable to communicate with it using the LM90 start utility. But i could on another CPU...
2,934
Hi All, I have just started using GE PLC and wish to check for some information. I was able to connect to my 90 - 70 PLC with COM1. I would...
2,909
Hi, I have gefanuc plc system 90-30 series and proficy m/c edition 5.3.My one NIU card showing LED status are BUS B and IO enable in amber...
1,491
