GE Fanuc Series 90 30 No Output
gearmachinist
Jul 2010
Georgia
We have a GE Fanuc Series 90-30 PLC on a Bar Feeder. We were having problems with the power supply and switched the old supply out. I used a Starts90.exe program that we found on this forum to put the PLC back into run mode. However, now nothing happens. The Input numbers are lit on the input panels but nothing on the output side and none of the bar feeder controls work. The PWR lamp was not lit on the old power supply when we changed it out but the battery appears to still be good. It appears to me that the CPU either has no program or has a problem. How can we check the program in the CPU? Is there an easy way to reload the program into the CPU?
Thank you,
Gary Jennings
My guess is if you switched out the power supply the program was lost. Are you familiar with the old DOS program LM9030? If you are then maybe you can find a copy somewhere to re-load your program, if you have a back-up copy.
We have a lot of those bar feeders in my area, most are quite old and use the CPU331 of which you must keep a good battery in the power supply to keep the program in the CPU.
A little more detail may be helpful.
I suggest that you locate a local integrated who is familiar with the GEIP (GE Fanuc) PLC.
Has anyone worked with on of these PLC's? If so, how do I connect to one? What software do I need? What cable do I need? I'm looking online...
661
Got an old machine with a IC610CPU104 CPU. A bit of research told me this is the same as DL305 so DirectSoft from AutomationDirect should work...
2,064
Dear Experts I need to connect to this CPU 374 It seems it is a GE Fanuc PLC I want to know if I will require any specefic cable - from the...
1,798
Is there any way to make a connection directly between a GE Fanuc 90-30 and a Mitsubishi FX Series PLC? If there is no means to connect directly...
21
4,223
I have a Fanuc Robot F-200iB Series 9, 6 Axis and it is running on R-J3iB controller and the controller is configured to Mitsubishi PLC Q06HCPU...
1,907
