GE FANUC series 90-30
Aug 2006
Tangerang
Dear Sirs
Please help me how much the price of PLC GE FANUC parts beloows:
1. Input Module 24 VDC 44A 729182-037R02
2. Input Module 120 VAC 44A 729182-002R06
3. and power supply for the above PLC GE FANUC
Thank you very much for your kindness
Indonesia
Henry manglassa
You should be looking for part numbers with the format IC693MDLxxxyy for I/O modules where xxx is a three digit number and yy is a one or two character string. For the power supply, the format is IC693PWRxxxyy.
The 44A numbers you cite are for circuit boards. People generally buy the entire module which includes the circuit board, the terminal strip, and the plastic case. Even if you could find someone to sell you the circuit board, delivery would most likely be longer than for the entire module.
Here is the part number for a 16pt 120VAC input card
IC693MDL240
16pt 24VDC Pos/Neg logic input card
IC693MDL645
Google them to figure out if thats what you need, there are varients.
What are you using to program your PLC? In your hardware config in Cimplicity ME you should be able to find various power supplys, cpus, input/output cards.......then just reference the part number for specifics.
Has anyone worked with on of these PLC's? If so, how do I connect to one? What software do I need? What cable do I need? I'm looking online...
661
Got an old machine with a IC610CPU104 CPU. A bit of research told me this is the same as DL305 so DirectSoft from AutomationDirect should work...
2,056
Dear Experts I need to connect to this CPU 374 It seems it is a GE Fanuc PLC I want to know if I will require any specefic cable - from the...
1,797
Is there any way to make a connection directly between a GE Fanuc 90-30 and a Mitsubishi FX Series PLC? If there is no means to connect directly...
21
4,217
I have a Fanuc Robot F-200iB Series 9, 6 Axis and it is running on R-J3iB controller and the controller is configured to Mitsubishi PLC Q06HCPU...
1,907
