GE Fanuc Series 90-30
Ron Brown
Nov 2005
NC
48
I am working on a project that has one of these PLC's installed already. I was able to get a copy of the ladder logic, I think anyway, but I do not have any way to open it up to look at it.
Any ideas on what I can do to get a print out of the logic for now. I am just trying to determine what I am getting into before I go to far with this project.
Thanks,
Here are pdf files of all program blocks.
It is not a simple application. The hardware configuration includes a single axis motion controller module and a high speed counter module. Be careful not to underestimate the amount of time you will need to get up to speed with those modules.
Thanks for converting these for me. I am sure there be more questions as I progress with this project.
Has anyone worked with on of these PLC's? If so, how do I connect to one? What software do I need? What cable do I need? I'm looking online...
661
Got an old machine with a IC610CPU104 CPU. A bit of research told me this is the same as DL305 so DirectSoft from AutomationDirect should work...
2,059
Dear Experts I need to connect to this CPU 374 It seems it is a GE Fanuc PLC I want to know if I will require any specefic cable - from the...
1,798
Is there any way to make a connection directly between a GE Fanuc 90-30 and a Mitsubishi FX Series PLC? If there is no means to connect directly...
21
4,219
I have a Fanuc Robot F-200iB Series 9, 6 Axis and it is running on R-J3iB controller and the controller is configured to Mitsubishi PLC Q06HCPU...
1,907
