Ge Plc
TheRixta
Sep 2002
MA
I havee written the ladder logic for a simple pump station that has a key panel but now that want it run from a PC. How do I switch the coils from a PC program without using VersaPro or Cimplicity?
Do you want the PC to be the operator interface to the process that is controlled by the PLC or do you want the PC to act as both the controller and the operator interface?
Cimplicity ME View or Cimplicity Plant Edition can act as the operator interface software. Cimplicity ME Logic PC can be the control engine.
Two down and dirty methods might be to set up the PLC com port as a modbus RTU slave or even a ASCI port.
The 1st would require a mobus master program on your Pc, the second use Hyperterminal on Pc and add to PLC program code to interegate serial string and convert it to a point/ value change.
The HMI option , Cimplicty ME view or a 50pt Cimplicity PE is far easier, and cheaper in the long run
Hi everyone. I'm trying to read values from a Loadcell with a 2080-TC card. I know the 2080-TC is a thermocouple card but it reads millivolts that...
63
Hello All, Please direct me to post to the right page. I am really new to PLC, and want to find a tutor who is familiar with Automation Direct's...
65
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
45
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
86
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
87
