GE PME Analog Control
LMBrian
Sep 2012
Florida
54
I'm using a Vmax Micro 20 with an analog option module on our system. I have 2 inputs open and close. They are to control a 4-20mA motorized valve. The operator must maintain either button to open or close. When neither button is pushed, the valve maintains its position. I'm a little confused as to the best function block/logic to use.....
Thank you.........
Hi I am wondering if the RXI-042 PLC model (below PN) is programable via Proficy Machine Endition, if so, what is the firmware version needed for...
107
Hello guys i have a HBM PME MP55 and i want to connect with a pc, what type of cable does it need because on its manual it say on a terminal 2...
328
I don't have much experience in programming. I can do simple configuration. it is like this. i want to add something to the existing ladder...
39
6,235
Converting a 90-70 LM90 to PME 9.5 and need some help with the migration errors and conflicts in the feed back zone. I have parameterized blocks...
829
Having specific issues with migrating a 90-70 PLC from LM90 to PME 9.5. Backing up the LM90 Folder importing into PME is fine however I do not...
865
