GE Timer addressing
MUITECstudent
Oct 2006
Lancaster PA
Quick question for anyone with GE knowledge.
Background:
We are replacing a Allen Bradley SLC with a GE 90/30 (long story). I'm converting the code manually.
Question:
In RSLogix, you can address the EN, TT, & DN bits of a timer.
In Proficy, I noticed that there are 3 words assigned to each timer - CV, PV, and control. In the control word, there is an enable bit and a status output bit. How do you address from these two bits?
-Bill
so im not exactly new, nor am i experienced at PLCs. i have an issue with a client that would require me to display numeric data on the HMI...
1,656
Hello, I still do not have equipment in to test. But the RTAC ladder does not have a timer reset coil. I wonder if a reset coil on Timer.IN is...
109
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
108
Hi all, I have a simple question that I have overcomplicated and gotten stuck on. I have a variable, we can call it "light" that I need to stay...
355
Question to anyone with ideas about my thoughts on upgrading a very vintage timer, which is being used to switch between 2 5hp domestic water...
459
