GE Versamex IC200EBI001 Fault Table Codes 9
zeroman
Aug 2019
perth
I am setting up a new GE Versamax drop with modules as below:
-IC200EBI001
-IC200PWR102J
-IC200CHS003M
-IC200MDL742H.
However, I find that I am not able to send an output LED to light up in the MDL742H. There is only LED to indicate OK. So, I used my diagnostic logic and it indicate Fault Code 9 which is 'LOSS_OF_USER_POWER_FAULT'. Anyone know what's that fault code mean?
Hi Steve,
Thanks for the reply, eventually i found out that day. I realised that you need field power source to drive the DO output. Thank you though
I have a cell with a compact guardlogix as the plc and I have three hmi's and two vfd's on this cell. I been experiencing momentary comms faults...
86
Any one give solution for this fault. We are using AB Gaurd logix controller(5573s), resent days we are facing major fault in controller...
81
I migrated to a WSP2023 application. Now when I open a HMI object (for example a valve or motor) the popup is first correctly show as defined ...
50
We had a site where a rat gnawed through some fiber optic cables which (obviously) prevented communication to a remote rack entirely. We, and the...
116
Good morning everyone I’m currently working on a omron device net and have a nord drive that fell off the network. I have limit knowledge in...
148
