GEfanuc 90-30, Commreq
macs_plc
Jan 2008
Nagercoil
120
Iam working on GEfanuc 90-30 PLC ICC693 CPU 363
software - proficy machine edtion
connectivity is modbus (two wire)
i want to connect this CPU to Numeriacal relay (upto 15)
usin g modbus...........
For that i have to use commreq function........i have already gone through some example programs........but i cant get it....
Experts having any crisp example of using commreq function....plz post it with screenshots.......with explanation
and suggess me how can i get the signals from that remote instrunment and make use of it using commreq function in
gefanuc 90-30 ..............................................
Go to the "download" section of this website. Choose "Other PLC Brands", you will see a zip file for "Com Request". This program is very useful.
Hi has anyone had any luck connecting to a 9030 series PLC using a USB-Serial adapter? I'm currently trying to use a Startech ICUSB232v2, with a...
2,253
Is there any way to make a connection directly between a GE Fanuc 90-30 and a Mitsubishi FX Series PLC? If there is no means to connect directly...
21
4,253
Hi, I have a pcm301 ccm mode in port 2, how I can change ccm slave to Modbus rtu slave? Link's for programming software pocof, termf, and Modbus...
18
3,423
Hi, Need some help with a 9070 PLC issue. It is a genius bus installation that performs periodic autotesting on field I/O. I am getting errors...
1,239
Hello Everybody... I'm Using IC694BEM331 Rx3i Genius Bus Controller and I need to update it's firmware . Kindly help me and let me know by how...
1,770
