gem80 plc to pc interface
Dec 2010
UK
I was wondering if somene can help me. I want to display certain input/output status on a dipslay screen. I have picked up that I can do this using something like Visual Basic. However with gems being not the most modern of choices, I don't have a complete picture of what I need to achieve this.
What I'm trying to do is to monitor I/O status ie is limit switch high/low and display this on the screen (along with other 100 I/Os). I only need a facility to receive a signal, not to transmit.
So far I have gathered that I need an OPC server which should make the link from the plc to the pc. (Can someone confirm this?) and an ActiveX control in Visual Basic to communicate with the OPC. Pricewise, I dont know what I'm looking at. I assume getting a SCADA package will be much more expensive for such a small task. Am I going in the right direction?
What Gem PLC are you using? We have some Gem500's which support the Modbus TCP protocol.
Although we are using iFix with an GeFanuc MBE driver you may want to have a look at Kepwares website, they sell a Modbus TCP driver and have some VB examples on how to do what you want to do.
If it supports Mobus/RTU, the AdvancedHMI project has a limited driver for Modbus. That gives you a free software option to display data.
I do plan to eventually complete the driver so that it supports all data types.
I am looking to converting the Gem80 PLC logic in to Rockwell PLC. I need GEM80 Instruction Manuals, and documents that help you to understand the...
2,408
Does anyone have any experience in speed up for scan time in PLC GEM80/400 Enhanced. Currently I have Problem with scan time too long so impact to...
1,786
Hi Guys Does anyone have any good link to information on the GEC GEM 80 PLC? Thanks F.
5,521
I have a GEM80 installation which I am replacing with a new system (Siemens). It has 8 renote I/O stations each configured with 16 word addresses...
1,260
What are the following rungs doing please |------| |-----|/|---<inv>----DELAY----VALUE----<inv>--------()--| G0.08 A1.06 G193...
1,015
