genset ignition controller problem
roxtech
Mar 2008
Township Lahore
198
Hi dears,
we have HCI IC-900 ignition controller. we are facing problem no ignition signel from controller to coils. we have check all three signels from speed sensors which is ok. power LED let, system LED in blinking. When try to start engine triger LED, Reset LED and cam LED flashing. but no ignition at spark plugs. If anybody have such experiance, please halp us.
Beast Regards
hic 900 ignition controller
usually there is a jumper at ignition controller if there is no ignition at the time of startup then check for this jumper. This jumper must be open at startup otherwise ignition controller will not work. That contacts are (sensor gnd,contact A)
Feel free for further inquiry
Faheem Munsif
03077777200
Dear All, Currently I'm working for PICO Hydro system that installed at remote rural area which there have no power supply from service...
1,482
Looking for a modbus reference for a comap IG-NT GC HW version 1.3. Any help would be appreciated.
1,567
We are building a testcell for testing diesel gensets. The maximum rating is 550KVA@400V. There is going to be a loadbank used for the...
3,831
Reaching out to all the seasoned folks, what would you use if you were to provide a 300 kW power generation system? A diesel genset or a...
17
6,184
Anyone know how the alternator splits from the perkins diesel ? I phoned Wilsons in Ireland to be told by tech support to remove the air guards...
2,578
