Get proccess data from SQL , using WinCC V6.0 !
Sep 2005
ho chi minh
Hi all !
As I know , WinCC V6.0 work with SQL Server 2000 ! I am making a project that I have to make report . I am using Visual Basic to connect database from SQL !
I want to know what will we get advantages ( about database) from SQL ?
I linked database (Access database) using tool of Visual Basic (Data Environment) and Data Grid to show the data ( IT was OK) . Now , I want to show the proccess data ( in WinCC) . Can I get proccess data (In Tags of WinCC) from SQL ? And how ? Where is my proccess data ( example : Archive , Alarm , value of tag ...) stored in SQL ? And how can I get them ?
Please help me !
Thanks and best regards !
Kiet
i need your help
i was wondering if you may know how to display the data on the grid from the database, i am also using wincc to retrive data from sql server, and i would like to display the queried data on to a data grid
any information on this regard will greatly be apperciated
Hi everyone, I have a 505 workshop program with PLC type of 555- 1106 and I was wondering how can I download the data documentation window as a...
93
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
67
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
79
67
182
