Getaway Profibus-Can Bus
unlock
Feb 2016
Milano
Hi all,
I'm new here, I've searched some documentation but i found nothing.
So my question is:
I must create in step7 the telegram for to read pdo and sdo from getaway, but I don't have any idea how to create the telegram and then send it
Somone can help me
:confused:
Sorry I've other question....how to use ob86 to trap error ?
and no i don't use awl but only kop with siemens
Hi Unlock,
SDO and PDO is used on CAN. So You will need some sort of hardware/gateway.
If you do not have any, I would suggest that you talk to Stefano or Giorgio at our Italian office, as I am sure that they can assist you.
+39 039 59662 27
BR
Patrick L
Call
Send SMS
Call from mobile
Add to Skype
You'll need Skype CreditFree via Skype
Hi Unlock,
+39 039 59662 27
I know SDO and PDO are used on CAN.I have getaway profipus, side PLC, can side motors.
Can I call Stefano or Giorgio without problem?
Well, I suspect that you have no Anybus gateway and that may be a problem... However, It does not cost to call... :)
how I can add the drive to the getaway RSLinx to communicate with a SLC500
3,067
So i need to communicate my VFD (LS Electric iS7) with XGL PMEB module i successfully set the gsd file now i cant figure out how the data works...
72
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
228
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
104
