Getting 1756-CNB diagnostics through CIP
panoskart
Oct 2009
uk
Hello there
I am new in the PLC programming stuff and I am working with an AB PLC Logix5000 series. I am trying to access the diagnostics of the ControlNet module through a cip message in order to monitor some alarms in case of a network problem. I have found some references up to now but they dont seem to work..Please see the attached picture for the configuration of my MSG command (the path is to the CNet module). The fault that I get is '16#005 no connection' and ' wrong class or attribute'. In the source tag I have set the 0000000400 in a Dint and 02 in an INT. Any help is appreciated. Thanks
. In addition is there a similar way to get diagnostics for the PLC processor in case of a fault?
See my attachment for the correct MSG setting, Source Element not needed. Then make sure the destination need to be an SINT (Short Integer) array with 6 element. And lastly your path pointed correctly to the correct ControlNet module.
Hi there
Thanks for the quick reply. Although the cip is now connected I still cannot see how to get diagnostics from these attributes..First of all, in the attached pic you can see the values that I have when online with healthy net. If I disconnect one Cnet tap I still have the same values alhtough there is a network error..Moreover can I find a reference of what is the attribute that each SINT looks at?
The application was working in Twincat 4022.16 Used VM for offline. recently changed the laptop and the getting the error with Message as below...
60
We are using wincc scada WinCC system software V7.5 SP2 , connected to few plc . Past 3 weeks we getting this alarm continously when we checked...
89
I am very, very new to PLCs. I only have experience with Picos, but I knew enough to save this from the dumpster. Apparently, everything on it is...
622
Hi, I tried today to get RD3A and WR3A instructions to work on the PLC and it didn't work, but it worked in simulation. I followed the clone...
18
1,441
Good morning guys; Im new at AB plc, and i just need help about a table or a list called something like "exchange data table" in French it is...
784
