Getting Started With WonderWare
demmons
Jan 2009
PA
87
I am going to be tasked with developing a new In Touch 9.0 application soon. My experience with WonderWare has been limited to getting into Windowmaker, building screens and correcting tags on existing applications. I have noticed that every application I have worked with has had a different communication set up.
Having worked almost exclusively with Allen Bradley and their HMI products, I am a little lost (okay a lot lost) with any communications protocols not involving RSLinx. :oops:
I will be connecting an AB industial PC to a controllogix PLC via ethernet, below are the details:
  • Versa View 6177RM4PXP running Windows XP
  • InTouch 9.0
  • Controllogix 1756-L55M12 via 1756-ENBT module
Does anyone have any suggestions on where to start in setting up the communications?
help you?
Hi demmons... Here is a little info and some pics.
You need to configure DASABCIP in Archestra Management Console. This takes care of almost all you need. This configuration of the DASABCIP configures a specific connection to a single processor (IP). Then you set up the access name in Intouch the DASABCIP that you configured above. I cannot tell you very well all that you have to do but I have included some pics here which demonstrates our config.
So basically this is your system architecture (50830-01.gif)
First is to setup your RSLinx to communicate with your PLC. Create a OPC/DDE topic in the RSlinx that point to the target PLC ( 50830-02.gif).
Wonderware is communicate using DDE natively which is compatible with RSLinx (only the OEM, Pro and Gateway support OPC/DDE server function).
Now setup the communication in the Wonderware by creating a new access name. Use "RSLinx" as Application Name and the topic name should match the topic name create in the RSLinx (50830-03.gif).
Last create all the tag you want to read from the PLC. The Item should match with the actual tag inside the PLC (50830-04.gif).
Now you are ready for your upcoming project! 🍺
For wonderware PC..Do not do following windows XP updates;
  • KB974112
  • KB969059
  • KB973869
  • KB971557
Then it will be okay...
One more pic of Acces Name config
attached jpeg - Ignore the Enable Secondary Source... this is optional and dependent on your system.
You guys are awesome. I really appreciate the feedback.
What I am seeing is two different ways using RSLinx or Archestra.
These are two of the configurations I have seen in the past along with WWRSLinx a long time ago.
I appreciate the screenshots and the time it took to make them, as well as the XP update information.🍺
If you guys were here you would get a round of Yuengling on me!
Do not use this method....way too inefficient. Use the DAServer instead.
Hello all, this is my first time working with a PLC and dealing with hardware, so please have patience with me. I have an electric rod-style...
21
3,117
Hey Guys, First post here and looking through, there are a lot of people that have different expierences and practices. A little bit of my...
2,043
Hey Guys, I have plenty of experience with AB plcs . What is a good starting point to learn about fanuc robot programming. How to get started? Is...
2,740
Hello guys, the company I work for has always worked with Allen Bradley, except for small applications with Siemens, which we would now like to...
16
4,743
Hello PLCS.net! I have a CPU315-2PN/DP with a CP343-1 attached to it. What are the latest and greatest software associated with it? How do I...
17
3,973
