glass temp senor
jimcav
Dec 2004
new jersey
229
Hello Guys,
Been away for awhile but I am back working in the manufacture world again. Working with glass now. I will jump right into it. I need a temp sensor that is non contact to read the temp of hot glass moving at a rate of 15 ft / sec. I would like it to be ethernet ip conpatable. Any manufactures you would sugest let me know.
jim cav
I'm not sure about Ethernet but I've had good performance from Raytek. I know they make an RS232 version that is on a network. Might be worth giving them a call.
If you try to use IR sensor for direct measuring of temperature without contact, you will have quite big error, as glass is transparent. IR sensors are good for measuring temperature on dark, non reflective materials. My suggestion is to put some kind of dark shim/pad in order to improve measurement.
We broke the glass on the new PanelView Plus 7 .... 2 months after the install. Our vendor stated that we cannot buy the repair parts...(Touch...
212
In the termination "server module" there are holders for three glass fuses. Is this just for convenience or are the fuses needed? If so, what are...
881
We are installing 20 foot direct burial fiberglass light poles, and we are mounting speakers for a pa system on the pole about 12 feet up. Can the...
1,831
Anyone know of any one that makes a small but Deep (10") Fiberglass or Stainless 4X enclosure? I only need the thing to be like 12"H X 12"W the...
1,182
A clients outdoor requirement is for a HMI to be mounted in an all weather (mainly heavy monsoon) enclosure. The touch elements on the HMI, should...
23
6,956
