GML Commander to 1394C Servo
sifis
Banned User
Oct 2005
OKC., OK.,USA
139
I am trying to connect a GML Commander to a 1394C Servo using USB to RS232 connector in WIN 7 / WIN XP.
GML Commander allows ports 1 to 4 only.
Win 7 / WIN XP assign a higher port than 4 (8,9,10).
So, no connection.
Any ideas?
Thank you.
I added a link to instructions...scroll down the the green highlighted "best answer" in the link:
http://www.tomshardware.com/forum/283047-45-configure-port-com1
After it assigns them, are you able to refresh your view in Device Manager and see them?
If so, try editing the COM number after the device in enabled.
Thank you,
I tried it, great help but no cigar.
Com ports 3 to 9 are in use.
I assigned it com port 1, it accepted it & then it reassigned to comm port 10.
Thank you.
GML Commander
Thank you,
Thank you.
How can I see what is in comm ports 1 to 9?
I want to free up comm port 3.
That is the port that GML Commander wants.
You may have to poke around in the BIOS of the PC to make sure there are not hardware devices using COM1-4.
Also, you may also try researching the particular make of converter you have for options to configure it to request or even reserve certain settings including COM number.
BTW, my USB 4G modem takes up com7, 8, and 10... Do you have other USB com devices plugged in?
Also, under the View menu, check Show Hidden Devices, just in case.
I have a 1394c-SJT05-C-RL Servo controller. The unit powers up. I cannot communicate using GML Commander. The light is blinking red on/off. Any...
1,928
1394 Assistance Needed I have qty 8 1394 units in various states of repair that I need to repair and test. 1394C-SJT05-T 1394C-SJT05-T-RL...
2,103
We have a machine with an Allen-Bradley 1394-SJT10-C multi-axis motion controller with two axis modules, both 1394-AM75. One of the axis module's...
20
10,231
GML Commander, OKIEPC, I am trying to contact you, your inbox email is full, please contact me asap. I am in OKC, OK., I can use your experience...
1,743
Where can I obtain a copy for use with 4100-234-R IMC ?
1,960
