Good rs485 Simulator/program
danieluy
May 2008
Manila
64
Anybody would like to recommend their favorite RS-485 PC Comm program?
i would like to connect DVP-PLC with Enraf Controllers and would like to make it easier if i can simulate or generate the correct codes first from PC...
thanks!!
after days of research and trial and error..
I've tried
-232Analyzer
-CAS Modbus Scanner
-Modbus Poll
-ModScan32
I'm trying to send the Modbus,Ascii,7e1, string ":010321020002D7"
and only ModScan32 did successfully sent the string... and got the correct response from the device.
maybe i did something wrong using the other programs?
I have done a lot of serial work in PLC5s and my favorite way to send test strings is to use the original 16 bit version of MS Terminal.exe that was provided with the early operating systems. It has 4 independent sets of 10 function keys which can be selected to appear at the edge of the comm window.
You can then setup your strings in the the Function keys configuration. Then you can click the function key and the string comes out the selected serial port. If you are expecting a response, it will show up in the terminal window.
Also, it can be configured to send and record plain text files or binary files.
If you check out a windows 95 installation, you will probably find it in the OS files. It does not need any special installation but the configuration can be saved in a config file that should be carried with it, if you move to another machine.
Best Regards,
Bob A.
I'm a big fan of RealTerm for debugging serial comms issues.
The sheer amount of options can be a bit daunting at first but after playing with it for a bit you soon get to feel your way around.
have looked at RealTerm and its phenomenal!!! it can even do I2C... :)
M gonna try also the MS Terminal... hmm... where do i dig-up my Win95 CDs......
Will try both programs and will feedback you guys... :)
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
260
Hi, Seeking consultation on an implementation matter, and have a question about Modicon Compact 984 communication through RS485: Three Modicon...
254
i have an device which can support serial (RS485,RS232),CAN protocol . i want to connect it to an existing MIB 1553B bus ,what device will I need...
106
Hi all, I am trying to do Modbus communications via the CB1241 RS485 Communication Board on a Siemens S71200 PLC. I am using a 1215C CPU. After...
279
I'm trying to use a Red Lion Cub counter (Cub5B00) as a counter and give the cub's counts to a Graphite G12 PLC/HMI to display. After about an...
122
