Good short 24VDC power supply?
rupej
Sep 2014
NC
967
I'm designing a small panel that my employer plans to build in-house and sell perhaps 10-20 per year? So I'm hoping to get the bill of material right the first time.
Does anyone have any recommendations on a short (around 3" tall or less) 24VDC Din-rail power supply? Only needs to have about 1A output, and a 110VAC input. Ideally, this would also be good quality and relatively cheap (around $50).
I've used this model WAGO in the past, but the screw terminals are very difficult to use, and also it's a bit pricey for what it is, ~$55.
http://www.wago.us/download.esm?file=\download\00303296_0.pdf&name=d07871002_00000000_0en.pdf
Thanks in advance!
Siemens logo power, model number: 6EP1331-1SH03
(HxWxD): 90x54x55 mm
A little bit to high maybe but it's good and cheep
When you say "short" I'm not sure if you mean height (parallel to the backplane) or depth (distance to lid). I'll assume you mean depth as that is the usual restriction.
I've used a lot of the Phoenix Contact "Step" power supplies. No failures yet that I know of. They are very low profile, around 2-1/2 inches.
https://www.phoenixcontact.com/onli...03-04-01/3436cd28-9205-4f36-8832-47a4df095fe6
Part number 2868635 for the 24V 0.75A version, available from most of the big name online suppliers.
+1 on the Mean Well (although, when they burn up we then refer to them as "Meant Well").
As a side note (as in way off topic), and mostly to you UK guys, I just installed a Mean Well in my ZX Spectrum +3 power supply case to get to work here in the States. Fit and works like a charm!
Hi group! Repeatedly found answers to some questions in the PLC's programming world, now I decided to ask the question directly) Now I am...
22
4,286
Hi All, I'm looking for some insight into what the SHORT instruction does. The help file wasn't very useful, as I found the explanation to be...
1,508
Congratulations are in order to those who are and still shorting TSLA. Oh man, I wish I had that courage of yours to go out and challenge...
106
23,467
Hi, I use Allen Bradleys 194e serie as load switch for my cabinets. The technical data confuses me, it says: On the general data it says...
2,020
Good Morning , I just recently did a project with several PowerFlex 525 drives. I just recently started getting a F 73 Fault ( EN Net Loss...
24
24,558
