graph on Simatic OP
marius
Apr 2005
239
i need to show active heating curve (let's say 10-20 points, temperature and time) on OP connected to 314/315cpu, i was working previously with op170b and text versions only, using protool/lite....
- is this possible using OP270 (upgrading to protool) ?
- is this even possible with any other simatic OP?
(like those wincc only)
i don't want to make crappy view from bars or single widthet lines ... ;-)
thanx
Hi Marius.
From OP/TP170B and up trend curves are possible.
You need to add a "Trend View" in the Protool project.
It is not simple to explain, but also not so complicated.
Have a go at it, and come back here if you have questions.
I'm programing OP170b at the moment and have to say, that trends are possible here. You can't use trend trasfer (block of values) and trigger the trend curve. It is only real-time scan. You can set the frequency of sampling and how many points you want to have on the OP170 .
Transfering a block of data or trigger the curve is possible from HMI OP270 upward.
yes, i meant non-realtime recorded curve, like Alfbox saying 'triggering curve'... so 270 would be my choice
thank you both
Marius,
I think it would be more reasonable to buy WinCC Flexible Advanced. You need it for new Simatic OPs and it is possible and recomended to program OP/TP170 upward with this programming tool..
Look at ebay.de.. sometimes you get it half the MLFB price.
Cheers
Well... if i count that price of upgrade from protool/lite to protool is about 700EU, than 1750 for wincc does not look so badly
ebay is also interesting hint, i'll need to learn more about it first
cheers
Wait. You only need Win CC Flex "Standard" to program OP270. You can always buy a power pack to upgrade to "advanced" at a later time.
edit: This is a sidenote, but before you go for Win CC Flex you should know that it requires a hefty PC. 3 GHz, 1 GB RAM, and a big screen (not so important for a project with OP270 I know).
Not a problem with most stationary PCs, but you will find that most laptops are ill equipped to work with Flexible.
You're right mate:
WinCC Flexible Standard is enough and MLFB price is just 990 EUR.
Here is a review of WinCC Flexible
  • SIMATIC WinCC flexible 2005 Advanced
  • SIMATIC WinCC flexible 2005 Standard
  • SIMATIC WinCC flexible 2005 Compact
  • SIMATIC WinCC flexible 2005 Micro
Various target systems can be configured depending on the selected product:
  • WinCC flexible Micro
    • Micro Panels: OP 73micro, TP 170micro, TP 177micro
  • WinCC flexible Compact
    • 70 Series Panels: OP 73, OP 77A, OP 77B
    • 170 Series Panels: TP 170A, TP 177A, TP 170B, OP 170, TP 177B, OP 177B, Mobile Panel 177,
    • C7 devices: C7-635 (Touch), C7-635 (Key) , C7-636 (Key)
  • WinCC flexible Standard
    • 170 Series Panels: TP 170A, TP 177A, TP 170B, OP 170, TP 177B, OP 177B, Mobile Panel 177.0
    • 270 Series Panels: TP 270, OP 270
    • 270 Series Multi Panels: MP 270B
    • 370 Series Multi Panels: MP 370
    • C7 devices: C7-635 (Touch), C7-635 (Key), C7-636 (Key)
  • WinCC flexible Advanced
    • Standard PC
    • SIMATIC Panel PCs: Panel PC 577, Panel PC 677, Panel PC 877
    • SIMOTION Panel PCs: P012K, P015K, P012T, P015T, PCR, PCR-Touch
    • SINUMERIK Panel PCs: OP010, OP012, OP015, TP012, TP015, OP015A
I am looking for a downloadable copy of Graph 5/II, anybody know where I can get it?
3,729
Hello Folks! I have an issue and its very often but in this case i applied all the tricks and tips that i always do in similiar issues but in this...
780
Hi all - Considering using S7 GRAPH for some sequencing. I have a few questions which I am having difficulty finding clear answers to in the...
581
Can someone explain the order of processing the actions of a step...is it top - bottom see attachment for reference. Does it process the blkmov...
2,077
the plant I am supporting uses a siemens graph function to do some of the step procedures. in several steps it waits for the step to execute for...
773
