GuardMaster 440-CR30 with 120vac??
steveb55
Jul 2015
Indiana
Greetings fellow Control freaks...
Ok... I just spent a week in Mexico doing a safety upgrade (along with a grab bag of "since you're here" requests). I simply reprogrammed the aforementioned SR, wired in some safety mats and light curtains, configured an HMI, blah, blah, blah. A week after I return I get an email from the local Controls guy that says they think they found a problem with the SR. (Well, it was working for a week, what's the problem, I think.) He goes on to say it has 120VAC on Terminal A1. WHAT?? I don't even think it will power up with 120VAC on it.
Someone please confirm that it will:
A - Blow up, or
B - Not power up.
I need to be sure before I send this guy a kindly worded memo to "Please confirm your diagnosis". They seem to think it has 120v on it and that I must have done it. (That would be tough since it was working before and after I left.)
Thanks guys,
Steve
A - Blow up, or
B - Not power up.
Thanks guys,
Steve
That is a 24 VDC unit only. They do not make a 120 VAC model.
As to what would happen if 120 VAC were to be applied it's tough to say without me having a look at the internal circuit but I would expect it to not power up at all from what you can see but i would expect the internals to be damaged. It may survive it depending on how it's built but in such a small cheap unit I doubt there is any protection like that.
It's really a moot point if 120 VAC was applied to it then someone messed up in a big way. Since it's a safety device I would be replacing the unit no matter what.
Thanks... Exactly my thoughts, but I wanted to confirm that I was not, and could not, be the one that goofed.
Completely agree with that and have already advised the same.
Thanks again,
Steve
Hello all. I am purchasing a CompactLogix to use as a server which will host 4 other PLC's (2 ControLogix, 2 Beckhoff) and a Fanuc RC. The current...
932
Hi All, On our site, we normally use trapped keys for our safety gates, however, for our newest project, I have been told that we will be using...
1,019
I am working on a project where an AB Guardmaster 440C is the logic solver for some SIL-rated interlocks. I need to be able to send reset bits...
761
Wizards, A little something out of the norm, I have a LoTo station that someone built for training purposes. It never got completed and the box...
1,988
Good Evening , I have some Rockwell Light Curtains and Guardmaster 440C-CR30 Configurable Safety Relays . I was wondering if there is any...
1,416
