GX Developer - Copying programs from other projects
Open the projects folder, inside should be a folder "Resources" then inside "POU" then "Body" there you will find all the programs as .WPG files.
You can copy them to another GX Developer project, just paste in the exact same folder in the other project.
If you want to check the used addresses you can either look on one of the menus should be a "List of used devices and search the specific program". It will only show you one type of device at a time. If you want all types, just keep the single program in a project and then "Print" under the options should be used devices, it will give you a print out of all the various used devices.
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
62
Well, I've decided to start a new project, and like all projects, it has already gone horribly wrong. I purchased a PLC device (supposedly a...
117
Does anybody have any samples of how to "Create and Use" UDT's in CCW Developer Edition? (I am using v22) I can't find any information from...
323
I'm trying to manually convert a Beijer E200 HMI project onto to a new Mitsubishi GOT gs2107-wtbd. The PLC is a very old A-series AS1CPU and is...
389
Hi One of the PLC's that I maintain/update is a Mitsubishi Q-Series, probably installed about 10 years ago. At the moment, ALL the wires from...
1,178
