GX Developer Newbie Help
LSPort
Dec 2016
uk
29
I am attempting to use GX Developer with a Q06 CPU, for the first time.
I am attempting to mirror a pre-existing 0-10v analogue output channel used to control a VFD to another separate channel for another secondary machine.
The card is part of an existing running system and is a Mitsubishi Q68DAV card.
I have always worked on Rockwell Products and I am now realising how different these systems are…
I have checked the configuration for the Racks and I can see that the addressing range for the card I want to use is something similar to XY02A0 ( I am doing this from memory )
When I online monitor in the returning value HEX is “ 1FE ” . I think this means that the status set up for the 8 output channels is all good.
My issue is I am unable to:
A,
Find out how to display the real time values for the respective channels. I have obviously been Bradley brainwashed..
I was expecting the format to be similar to
Y02A1 Card CH1
Y02A2 Card CH2
Y02A3 Card CH3
But when I enter for example Y02A1 into any off the device monitor screen I don’t return the dynamic channel value.
What am I doing wrong ??
B,
If I figure out what I am doing wrong is it plausible to write some code which is similar to
Source Destination
[ MOV Y02A1 Data Y02A3 Data ]
Thanks in Advance.
I am using gx developer ladder here is the problem http://imageshack.us/photo/my-images/233/solinoid.jpg/ Mine version not work...
1,358
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
61
Well, I've decided to start a new project, and like all projects, it has already gone horribly wrong. I purchased a PLC device (supposedly a...
115
Does anybody have any samples of how to "Create and Use" UDT's in CCW Developer Edition? (I am using v22) I can't find any information from...
321
I'm trying to manually convert a Beijer E200 HMI project onto to a new Mitsubishi GOT gs2107-wtbd. The PLC is a very old A-series AS1CPU and is...
387
